ROZMERY DORAZOV ZADNYCH TLMICOV
- stan
pomozte s vyberom
Closed Cell Foam Polyurethane Bumpstops
Bumpstops Special Foam Bumpstops
PIC BUSH
DESCRIPTION PART
NUMBER PART REF
ON DRAWING SIZE RETAIL
PRICE (£)
Special Foam Bumsptop SAF005 Bore 20mm 81 x 53 dia (mm) 7.95
Special Foam Bumpstop SAF009 Bore 15mm 30 x 50 dia (mm) 7.95
Special Foam Bumpstop SAF014 Bore 20mm 60 x 57.5 dia (mm) 7.95
Special Foam Bumpstop SAF016 Bore 12-22mm 58 x 56 dia (mm) 7.95
Special Foam Bumpstop SAF017 Bore 12-16mm 60 x 52.5 dia (mm) 7.95
Special Foam Bumpstop SAF018 Bore 12-19mm 72.5 x 58 dia (mm) 7.95
Special Foam Bumpstop SAF019 Bore 12mm 19 x 40 dia (mm) 7.95
Special Foam Bumpstop SAF022 Bore 12mm 55 x 40 dia (mm) 7.95
Special Foam Bumpstop SAF024 Bore 18-22mm 54 x 57 dia (mm) 7.95
Special Foam Bumpstop SAF025 Bore 19-22mm 50.5 x 51 dia (mm) 7.95
Special Foam Bumpstop SAF026 Bore 10-12mm 65 x 51 dia (mm) 7.95
PIC BUSH
DESCRIPTION PART
NUMBER PART REF
PRICE (£)
ford mondeo kombi mk4 1.8tdci titanium, mondeo mk3 ST titanium X 2.2 tdci 136kW
- jamaka
- jamaka
nic nerez!!!! skus to len poriadne zatlacit smerom hore a malo by to povolit z takycho troch bielych zubkov, potom to len das spet. Alebo hormalne vyber tlmic. Nie je to az tak moc roboty, je to celkom rychlovkastan píše:sakra, vidim to tak ze to budem musiet asi rozrezat aby som sa k tomu dostal
- stan
nie, dal ho na zvihak a stiahol ten plast z dorazu a potom stiahol doraz z puzdra, na zadnom nie su tie biele zubky je to iba valec na hornej casti so zuzenym hrdlom, 10min zalezitost, moja lenivost, ale dik za pokarhanie
, teraz vyberam dorazy ale su kratsie skoro o polovicu tak neviem
