Obvodovy alarm
popins
Re: Obvodovy alarm
Příspěvek od popins » 15.05.2015 18:03
Zdravim, nedaří se mi aktivovat obvodový alarm, po aktivaci nevidím informaci o otevřené kapotě (k zámku mi nevede drát) a alarm samozřejmě nefunguje. K infu v podpisu bych doplnil že mám focuse před FL, ale už má červené budíky a nemám dvojité zamykání.
Přikládám okomentovaný log z elmconfigu, kde se mi jeví vše v pořádku, pokud to tedy zapisuje správnou informaci na správné místo :)
#cteni
16:53:56.687 < 726 03 22 D1 00 00 00 00 00 readDataByCommonId: DID D100h
16:53:56.968 > 72E 04 62 D1 00 81 00 00 00 ok -> data: 0x81h (session 81h is active)
16:53:56.969 < 726 02 10 87 00 00 00 00 00 startDiagnosticSession 87h
16:53:57.247 > 72E 02 50 87 00 00 00 00 00 ok
16:53:57.247 < 726 03 22 D1 00 00 00 00 00 readDataByCommonId: DID D100h
16:53:57.529 > 72E 04 62 D1 00 87 00 00 00 ok -> data: 0x87h (session 87h is active)
16:53:57.530 < 726 02 21 03 00 00 00 00 00 readDataByLocalIdentifier, DID 03h
16:53:57.808 > 72E 06 61 03 04 0C 91 06 00 ok -> data: 0x040C9106
#zapis
16:54:34.992 < 726 03 22 D1 00 00 00 00 00
16:54:35.272 > 72E 04 62 D1 00 81 00 00 00
16:54:35.273 < 726 02 10 87 00 00 00 00 00
16:54:35.579 > 72E 02 50 87 00 00 00 00 00
16:54:35.580 < 726 03 22 D1 00 00 00 00 00
16:54:35.862 > 72E 04 62 D1 00 87 00 00 00
16:54:35.863 < 726 06 3B 03 C4 0C 91 06 00 writeDataByLocalIdentifier: DID 03h, data 0xC40C9106
16:54:36.140 > 72E 02 7B 03 00 00 00 00 00 ok
16:54:39.401 < 726 03 22 D1 00 00 00 00 00
16:54:39.680 > 72E 04 62 D1 00 87 00 00 00
16:54:39.682 < 726 02 11 01 00 00 00 00 00 ecuReset
16:54:39.959 > 72E 01 51 00 00 00 00 00 00 ok -> reset GEM
#cteni po zapisu + resetu GEM
16:55:16.916 < 726 03 22 D1 00 00 00 00 00
16:55:17.192 > 72E 04 62 D1 00 81 00 00 00
16:55:17.194 < 726 02 10 87 00 00 00 00 00
16:55:17.470 > 72E 02 50 87 00 00 00 00 00
16:55:17.472 < 726 03 22 D1 00 00 00 00 00
16:55:17.753 > 72E 04 62 D1 00 87 00 00 00
16:55:17.755 < 726 02 21 03 00 00 00 00 00 readDataByLocalIdentifier, DID 03h
16:55:18.031 > 72E 06 61 03 C4 0C 91 06 00 ok -> data: 0xC40C9106
Dále ještě přikládám screenshot toho jak jsem to nastavil (nikde nic dalšího jsem nenastavoval??) a pak další kde jsou vidět verze HW a SW GEMu. Nemůže být problém v tom že hw je BB a sw AB (Ax verze by to neměli umět podle toho co jsem zde četl)?
Měl by někdo nějakou radu? Popř. mi potvrdil že jsem to aktivoval korektně? předem díky...
nastavení pro aktivaci alarmu
verze HW + SW
verze HW + SW
Ford Focus II, 08/2007, 1.6 TDCi, 80 kW, DPF
Andymaniac
Re: Obvodovy alarm
Příspěvek od Andymaniac » 15.05.2015 22:24
Aby to zacalo blikat a houkat, je potreba jeste zaskrtnout panic function.
Motor: 1,8 TDCi
Výbava: GHIA
popins
Re: Obvodovy alarm
Příspěvek od popins » 17.05.2015 11:07
Andymaniac píše:Aby to zacalo blikat a houkat, je potreba jeste zaskrtnout panic function.
Bohuzel v tom chyba nebyla, porad to nefunguje
Re: Obvodovy alarm
Příspěvek od ZaQik » 17.05.2015 11:15
panic function nikdy nezatrhavam ... alarm nefunguje znamena, ze ani neblika?
nechas stazena okynka, zamknes auto (blikne?) a po minute prostrcis ruku dovnitr a otevres si vnitrni klickou
popins
Re: Obvodovy alarm
Příspěvek od popins » 17.05.2015 11:51
ZaQik píše:panic function nikdy nezatrhavam ... alarm nefunguje znamena, ze ani neblika?
presne takhle to delam a ani neblika, prave ze mi to nehlasi ani otevrenou kapotu jak bych po aktivaci predpokladal (nevede mi k zamku drat)... nemuze s tim souviset verze SW gemu (AB)? viz muj prispevek o neco vys.
Andymaniac
Re: Obvodovy alarm
Příspěvek od Andymaniac » 17.05.2015 14:11
Ja když jsem to nemel zaskrtnuty, tak mi to nefungovalo :nixw: Tak me napada, proklamoval jsi na GEMu teda spinac kapoty ? Ted nevim co se stane, pokud s "otevrenou" kapotou zamknes. Mozna se alarm neaktivuje :!: :?:
Motor: 1,8 TDCi
Výbava: GHIA
Adow
Re: Obvodovy alarm
Příspěvek od Adow » 17.05.2015 14:32
No určitě se neaktivuje, to je jasná věc. Otázka ale je, proč auto otevřenou kapotu nesignalizuje... To proklempvání určitě stojí za pokus.
Re: Obvodovy alarm
Příspěvek od ZaQik » 17.05.2015 16:26
pokud dal klic do polohy II, tak auto musi hlasit kapotu - pokud nehlasi, tak je chyba v GEMu ... mas vyvedeny z GEMu v C100 pin pro alarm?
myslim si, ze tenhle GEM asi alarm neumi
popins
Re: Obvodovy alarm
Příspěvek od popins » 17.05.2015 18:56
ZaQik píše:pokud dal klic do polohy II, tak auto musi hlasit kapotu - pokud nehlasi, tak je chyba v GEMu ... mas vyvedeny z GEMu v C100 pin pro alarm?
pin proverim, ale dostanu se na to asi az o pristim vikendu, zatim diky za rady
ly-lu
Re: Obvodovy alarm
Příspěvek od ly-lu » 02.06.2015 14:57
Mám možná hloupý dotaz. Lze tento obvodový alarm zprovoznit i v autě s keyfree systémem?
Jedná se o Ford Focus II 2006
Případně co za alarm byste mi doporučili?
Díky
je: (Žabička) Focus II 1.6Ti-VCT 85kw, 2006, combi, sublime green, 166tis km
byl: Focus 1.8 TDCi 74kw, 2002, stříbrný, combi
byl: (Stříbrák) Escort 1.8 TD 66kw, 1997, stříbrný, combi, 320tis km RIP
Re: Obvodovy alarm
Příspěvek od ZaQik » 02.06.2015 15:03
lze
pavel 1.6
Re: Obvodovy alarm
Příspěvek od pavel 1.6 » 04.08.2015 08:14
Nepřemýšlel tu někdo o doplnění obvodového alarmu o otřesové čidlo?
Jednalo by se třeba o rtuťový spínač (rozpínač),který by byl v serii s čidlem kapoty.
Napado mně to po té,co tu jednomu právě šlohli skauta tak,že ho natáhli na vozejk,který taky ukradli. :nunu:
Ford Focus II 1,6 16V Titanium 5dv., r.v. 2008
viduka55
Re: Obvodovy alarm
Příspěvek od viduka55 » 04.08.2015 10:46
Otresove cidlo u ktereho jde seridit citlivost je fajn. Sam ho mam namontovane, ale ne na alaram ale na gps tracker. Tzn. pri jeho sepnuti mi prijde sms.
Obrázek Obrázek
pavel 1.6
Re: Obvodovy alarm
Příspěvek od pavel 1.6 » 27.08.2015 21:04
Ještě dotazy:
Bude stačit pro aktivaci alarmu 0.5s inpulz z otřesového čidla? Bylo by zapojené v sérii s kapotovým čidlem.Konkrétně je to Jablotron CA-550.
Jak dlouho ten alarm houká?
Adow
Příspěvek od Adow » 27.08.2015 21:07
Pro aktivaci to stačí určitě. Jen dej pozor s tím čidlem. Aspoň co se kapoty týká, tak Jablotron používá na aktivaci zem. Zatímco Ford to má opačně - alarm se aktivuje, když se zem třeba že spínače ztratí.
